I want to increase the priority to forty-two and SpeedUp-forty-two no longer works. Can I just renice mpeg2enc and mplayer and ??? or is there more to it?
A few weeks ago SpeedUp-forty-two started quitting after asking for my password. Is there a way to get it working again?
Or perhaps I am missing something... Do I need to drop forty-two onto SpeedUp-forty-two every time I want to speed up forty-two or is it a one time program? It just occurred to me that maybe SpeedUp-forty-two changes something permanently so I might only need to run it once.
Thanks,
-Roger
That figures. I was trying to activate it every time I launched forty-two.Originally Posted by JellyBean
Any suggestions on the best way to renice the processes associated w/ forty-two? I want to run them up to +19 or +20 when I am off that computer. I know the syntax but I need to know if this will cause any problems.
Thanks,
-Roger -
AnonymousGuest
If you read the "docs" carefully , you will see that Kai warns of reniceing. Read the documentation carefully Roger.
Actually I have. I have also seen posts indicating that reniceing should help. Hence the reason for this thread.Originally Posted by JellyBean
I am hoping for a definitive post from Kai on this.
I am currently running forty-two and have reniced mpeg2enc, mplayer, yuvscaler, and cat to -20. Things are now running significantly faster. What was a 23 hour transcode at a nice value of 0 is now 17 hours after running an additional hour at -20.
-Roger -
I would like to request clustering capabilities . I have 4 Macs running OSX on my network and would like to use those idle cycles to help speed up forty-two. Would this be hard to do?
Reversing PAL speedup.
By rcavanah in forum EditingReplies: 3Last Post: 22nd Sep 2011, 13:26 -
Converting MKV (H264/DTS) + Speedup to 25fps for PS3 Playback > Help Needed
By flexx in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 06:28 -
Reversing PAL speedup and frameserving
By Ennio in forum Video ConversionReplies: 23Last Post: 28th Jan 2010, 15:28 -
compensating 4% PAL speedUp on playback of a dvd (Mac user)
By zep in forum Software PlayingReplies: 11Last Post: 18th Jan 2009, 23:43 -
PAL Speedup / 24th frame repeated questions
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 6Last Post: 12th Oct 2008, 17:35
