i have 2 questions. first is what is the best codec to use for capturing to an AVI file? i am useing ati's mmc7 and capturing AVI and i am useing mpeg4 v2 in the custom settings. i have found this one to have the best quality so far but is their a better one. this one has some blockiness in it and i'd like to eliminate it. second question is, in the custom settings for capturing an AVI there is no selection for capturing at 352x240. is there a way to change it so i can? thanks......
Go here have a read : http://www.vcdhelp.com/capture.htm
AVI = uncompressed - VERY BIG files - 352*240@29 fps gives about 4 minutes 45 seconds to a 2 Gb file
Depending on capture card/ computer and personal quality needs : MJPEG is a good CODEC.
I use Virtualdub to capture [ http://www.virtualdub.org/ ] and my card let's me customize size.
If capture card allows :
1. capture AVI @ 352*240
2. use TMPEGEnc to encode your VCD - i use the 2 pass VBR feature and it give OK results when viewed on a TV.
Which codec is the best for capturing VHS?
By aaxpers in forum Capturing and VCRReplies: 2Last Post: 27th Jun 2011, 06:45 -
Need basic info on Simple profiles when capturing video with XviD codec
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 21:54 -
Use a software codec when capturing with an ADVC300?
By timothyd_1975 in forum Capturing and VCRReplies: 22Last Post: 15th Jun 2009, 23:06 -
Best compression codec to use when capturing 720p video?
By Mysteriouskk in forum Capturing and VCRReplies: 3Last Post: 24th Nov 2007, 23:51 -
Which Codec is the Best for Capturing?
By rocknico100 in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 20:47
