Okay..i want to put a 88 min audio file on a 80 minutes CD. Does anyone know if i can overburn that much time using an HP200i?
It also says this at Nero:
Since normal CD-Rs are not designed for this amount of data, there may be errors at the end of the CD. You might also damage your CD recorder. Use this option at your own risk!
I was wondering if anyone has overburned anything with the 200i and if there was any problems...thanks alot
well don't know if you can overburn that far with a 80min. CD-R I only thought you could go to 82min., I have tried the 99min. CD-R's and the drive will not even see them even though my 12x HP CD-R writer does.
VOB File and CD overburn Query
By scott274 in forum Newbie / General discussionsReplies: 8Last Post: 17th Nov 2009, 01:54 -
Overburn Writing
By g_pentium in forum AudioReplies: 6Last Post: 7th Aug 2007, 09:08
