  1. I couldn't seem to find a guide to do this.
    Feb 2001
    Macondo, Puerto Rico
    What software are you using?
    You can set the mpeg2 file as the play first movie in Ulead DVD Workshop.
    Regards,
    Jose Febus
  3. I can basicly use any software that i can download.
    i'll try Ulead
  4. IFOEdit (freeware) can do this, there should be guides for it to the left or at doom9.org
    Ulead has a 30day trail ver you can use as well. DVD Maestro is another good choice (I d/loaded it from somwhere )
  5. How do i load the Mpeg2 in IFOedit?
  6. i order to use ifoedit you will need to seperate the audio and video. use tmpgenc to do that.
