I tired to open up a DivX film in Virtualdub 1.5.1 and it popped up an error and then the error disappeared, in a matter of 0.5 of a second, so I can't see the error. Do you think it's a problem with the film or just that Virtualdub can't handle DivX films?
Results 1 to 13 of 13
Why are the best things things in life cost the most money?
Who stole the rest of my Signature, Own up, it was you, yeah you, thats it I am gonna come over there and .......... -
If you have DivX codecs, then you should be able to handle DivX movies. Have you loaded all your codecs?
Hello. -
This is the error I am getting when accessing the Divx file I am trying to convert.
I have downloaded a VFW codec which I installed and I am not sure if I gotta configure with Virtualdub, and after installing it, it did nothing to correct the problem.Why are the best things things in life cost the most money?
Okay, have downloaded your Nimo codecs (from the Tools section at left)?
Hello. -
Update, I tried a smaller DivX and it's come up straight away, so I am thinking it's the film. If it is can it be repaired?
You still need to verify you have the right codecs. I see no reason to go on until you do.
Hello. -
I downloaded the Nimo codec Build 8 and yes that was the error I got!
I have also installed Etymonix Video Codec (shareware for VFW Codec)Why are the best things things in life cost the most money?
Nope, I get this error:
oh...using Nimo codec build 8......I think taking a hammer to your PC would work better.
Use only the following
Divx Pro 5.03
Xvid codec Koepi (stable version).
Nimo looks nice....but it crashes everything....with build 8 being the best at crashing. -
Yes, stay clear of Nimo, and especially build 8. I was on the verge of reformatting, as suddenly nothing worked after install (WMP, TMPGEnc, VDub...). For each AVI that wont work, use gSpot to tell you what codecs are needed. Then locate and install these and only these.
/Mats -
Weird, I uninstalled Nimo Build 8 and installed DivX pro 5.0.3 full and it's loaded up perfectly, thanks guy's it seems Nimo doesn't have what it takes.
Wierd, yes! I always recommended a codec pack in cases like this before, but after my experience with Nimo 8, I strongly discourage these codec packs!
/Mats
Using VirtualDub 1.10
By eteaneck in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2011, 16:50 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
virtualdub vs others
By dude112 in forum Video ConversionReplies: 13Last Post: 13th Nov 2008, 23:49 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
re: virtualDub
By merlie in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 15:50
