is there a way to split the voice and music from a song file (mp3, wav, etc)?
i just want some instrumentals of some songs and i cant find them anywhere...
thanks in advance.
There are some sound programs that have remove vocals functions. I know Gold Wave has it, but the results are not that promising.
Hello. -
If the vocals are centered in the stereo spectrum, any of the vocal removing programs will reduce the vocals volume but may not delete it entirely. It may alter the sound also.
A free vocal remover can be found at www.analogx.com in the music software area. -
you will never be able to remove the vocals entirely. Like unclebud said, the vocals need to be in the centre of the audio for it to work. Anything else is like trying to un-bake a cake to get the eggs out.
Bartman 8) -
thanks guys. that helped greatly! but, it didnt help with the songs i wanted to remove the vocals from
how can i tell if the vocals are centered setero without acutally opening the song in the program? -
Just listen to the song through some headphones. If the vocals sound like they are in the middle then you have centered vocals (most, if not all songs, have the main vocals centered)
