ok i have windows xp corporate edition and no mattw what i do i cant get the encoder to wrk on here it always just encodes half tyhe file then quites or not even come on at all
i was wondering if neone here knew how to fix this prob
I'm running winXP Pro and have no problems with TMPGenc. I assume you tried d/loading and re-installing the program already. Do you have problems with all files, or only certain files, (or have you only tried the one file so far).
Do you have directX 9 installed? Do you have directshow enabled in the VFAPI environmental settings? -
Pink, did you install XP clean or was it an update to another OS? If it was an update I'd reformat and re-install. I've been running TMPEnc on XP corporate for more than a year now without any issues.
Rick -
it is a fresh install i made form the corporate with service pack 1 integrated... i have had problems with The new Guy and Romeo and Juliet
i will try to get a new ver of tmp tho maybe it will work better
thanx -
ok got a fresh install and everything andi try to encode a file then it only goes 1h 10 min in to the file then gives me a blanck screen... what have i done wronge. howdo i make it work with the hole file.. i never had this probelm when iwas useing windows 2k pro but now all of a sudden i have this prob in xp... is there somethgin i did wronge ?
Win 7 Pro install on multiple computers
By videobread in forum ComputerReplies: 1Last Post: 11th Nov 2011, 15:33 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 16:06 -
prob megui with win 7 T.T
By lainexperiments in forum Newbie / General discussionsReplies: 8Last Post: 30th Jul 2010, 05:00 -
How to in Adobe Premiere Pro 2.0 (Win)
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 2nd Oct 2008, 20:45 -
Win DV sound prob
By prcole18 in forum Capturing and VCRReplies: 7Last Post: 14th Jul 2008, 16:07
