Setup :-
NEC ND1000A DVD+RW (2 weeks old)
Abit SA6R MBoard
Windows 98se (FAT32)
VOB instant CD/DVD v6.5
Problem
Windows insists on sizing my DVDRW's as 650 MB, or occasionally 4.7GB but read only, or various oddities in between.
VOB instant disc works - sort of, enabling me to copy large AVI files (3.8GB) to the DVD, but then refuses to let me copy or drag them back to the hard drive producing various error messages.
Have successfully copied audio CD to CDR/W using Vob instant copy.
Also succesfully produced set top playable DVDs using pinnacle express.
Windows has allocated standard CDrom driver(none supplied with drive or apparently available) and no amount of tweaking or updating forces any change.
All in all my system seems totally confused by this hardware even refusing to read known good CDr's . (Previous HP CD RW worked fine)
I suspect some form of configuration/driver problem or whatever.
Have tried all the obvious (uninstalling rebooting - Reinstalling rebooting etc.) to no avail.
Previous posting brought no replies - now getting desperate - Please somebody help!!!
Derek
I've been having the same problems with my own DVD burner (sony DRU-500A) and Windows 98se. Windows keeps saying that my blank DVD-Rs are audio CDs with 2 gigs of data on them, but if I eject the disc and try it again sometimes Windows will say the disk is a 650 cd-r disc. I've tried numerous things and nothing seems to help. I'm going to try a newer version of Windows and see if that does anything. If it does, I'll let you know.
get winxp, win98 wasnt made for dvd writers. i have the same dvd+rw and running winxp without any problem./
Hi,Originally Posted by jacknjt
I've upgraded to win XP (and for other reasons changed my MB/Processor in the process).
Things are a little better in as much that XP now sizes the disc correctly, however I still have one problem in that if I right click the drive and select
"instantwrite DVD+RW format" it fails.
If I try dragging files to the disc it states "cannot copy file - disc is write protected".
I can drag and drop within the VOB instant program but even within VOB I can't delete the individual files only erase the whole disc.
Do you have the same problems ? Are you using a different program to VOB instant CD/DVD?
AS you have this drive working OK I would appreciate any pointers,
BR
Derek
ripbot264 not working properly with Windows 7 x64 - finishes in 1 sec ???
By xlr8r18 in forum Blu-ray RippingReplies: 14Last Post: 8th Jul 2011, 20:04 -
LG RH2T80 - won't recognise DVD's
By Dalene in forum DVD & Blu-ray RecordersReplies: 3Last Post: 17th Oct 2010, 00:34 -
recognise whether a DVD is Shrinked or Untouched
By ppeterr in forum DVD RippingReplies: 10Last Post: 28th Dec 2009, 21:41 -
Windows Media Encoder not working properly in remote desktop
By George2 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jun 2009, 00:14 -
MPEG2 file plays in windows media player but not properly in premier cs3
By ibanezfreak in forum EditingReplies: 1Last Post: 20th Oct 2008, 04:42
