Hi all,
I'm trying to convert a .mpg file to DivX using Virtual dub, 63806 frames out of the 85027 were processed and then an error came up as follows:
‘MPEG - decode error: not enough data to decode frame.'
How do I fix this MPEG? I have searched in the forum for answers to this problem and have found the following post to a similar problem.
1 Use TMPEnc to demux the audio"
2 Use a decoder to decode to WAV"
3 Use the WAV as input to virtualdub"
Ok, I understand No. 1) how to Demux in TMPEnc. The resulting audio file has been converted to a Mp2, is that correct?
2) How do I decode to a WAV? with what software?
Then I need to use the WAV as input to virtualdub. Not sure how to do this. Don't I need to DeMux again?
Is there a more detailed guide as to how to do this?
Your help would be appreciated greatly appreciated.
Elle![]()
Hey Ellebear,
I have a possible solution. I had somewhat the same problem. What I mean is that the same error message: ‘MPEG - decode error: not enough data to decode frame.' came up for me. What I was trying to do was convert the audio from an mpg file to wav. Like u, I look on the forum and didn't find anything that helped. So I converted the mpg to mpg using TMPGEnc. U know, so it'll fit on a VCD. So then I took the converted file and used VirtualDub to extract the audio and what do u know... it worked. I had absolutely no problem.
I hope this helps. Please tell me if it does or not. Write me:
DiscoverPlatinum@hotmail.com.
or I'll keep checking the forum to see if u posted that it worked or not.
- DiscoverPlatinumEvery woman is a black woman. -
Thanks DiscoverPlatinum,
I'll give it a try and let you know how I go.
Cheers
Elle
VirtualDub Audio Error
By aaxpers in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2012, 09:01 -
VirtualDub Error: The audio streams have incompatible data formats
By UMO in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 03:38 -
VirtualDub doesn't decode H264/AVC (MP4/M4V)
By klischee in forum Video ConversionReplies: 4Last Post: 3rd Mar 2010, 09:58 -
Error While Encoding Audio On VirtualDub
By ashwin.terminator in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2009, 10:00 -
VirtualDub 1.8.6 = Error about Audio (VBR) ??
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 28th Oct 2008, 11:55
