I need help rencoding the audio in a divx to MPEG2 Layer 3?
Provided you have MP3 (MPEG-2 Layer III) codecs installed, and also VirtualDUB, you can open the DivX file from VirtualDUB, select for Video "Direct Stream Copy" (you don't need to waste time to re-encode video and loose quality at the same time). Then, for audio, select "Full Processing mode" and in Audio-Compression select the codec (MP3) you have configuring the options you want (e.g.128kps, 44kHz).
Look in the tools section if you miss any of the needed tools.
RgdsThe more I learn, the more I come to realize how little it is I know.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
