I use dvd2mpg and I wondered what is the diff between BiCubic Filter or Nearest Neighbourhood?
Because I tried both on a small clip and I didn't notice a diff? I am asking because I want to use the bbmpeg plugin but it is supper slow! But Nearest Neighbourhood is a bit faster.
Does any body know how to get it faster or another free plugin that is fast?
I have links to some pics I took below:
BiCubic Filter:
http://homeiss.com/bicubic.jpg
Nearest Neighbourhood:
http://homeiss.com/nearest.jpg
<font size=-1>[ This Message was edited by: Homeiss on 2001-09-08 16:52:51 ]</font>
Record some video with small text, so small you can barely read it. You should see that the Bicubic filter will make the video look better (easier to read) when you use the bicubic filter to make a smaller frame.
You will be killing quality if you use nearest neighbour.
As skittelsen stated, bicubic resize helps sharpen/maintain the detail which can be lost when you reduce the framesize. If you are doing a DVD rip, I strongly suggest you use bicubic resize.
If you are using bbMPEG, then that's the problem. It is quite slow and not the best quality MPEG encoder either. You should try a faster (and better quality) encoder (e.g., TMPGEnc or the Panasonic MPEG encoder for MPEG-1).
Regards.
Michael Tam
w: Morsels of Evidence -
BTW, I'm kind of curious. Just how much faster is "nearest neighbour" vs. "bicubic" anyway?
Regards.
Michael Tam
Not On a 3 minute film it would have taken about 45min BiCubic I think, and about 30min Nearest?
So not to much...
KMPlayer and bicubic scaling
By Asterra in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 05:10 -
FFMpeg - warning: first frame is no keyframe - Encode to nearest keyframe?
By mh2011 in forum EditingReplies: 0Last Post: 3rd Nov 2011, 16:58 -
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 18:27 -
Nearest Neighbor Video Resize?
By jenna12 in forum Video ConversionReplies: 2Last Post: 18th Mar 2010, 14:50 -
Does HD-DVD player also rewind/FF to the nearest key frame?
By grasswhopper in forum Authoring (DVD)Replies: 1Last Post: 2nd Oct 2007, 01:13
