I've got a question for anyone that can help me out.
I have a DVD-R that i KNOW has a read error on it. It freezes at a certain point in the movie and if i fast forward past it will continue on with the movie.
I want to make a copy of the DVD-R in question but I can't figure a way to do it. I've tried making a straight duplicate of the DVD-R to another DVD-R but it won't let me because of that read error.
Is there a way that I can rip the vob files and take out the bad sectors that are causing the error? Or Any other way that you can think of to get around it would be most appreciated.
Thanks,
Brougham
Results 1 to 9 of 9
Is there a program out there where i could capture it frame by frame to even an mpeg and skip the bad frames?
I could re-encode it to mpeg-2 then.
Any suggestions on a solution... anyone? -
DVD Decrypter is the best and only one to ignore those error. I did make copy of all error DVD without any problem. Here is the setting --- Check the FAST ERROR SKIP box, set the HARDWARE READ ERROR RETRIES to 0, set the SOFTWARE READ/WRITE ERROR RETRIES to 0, check the IGNORE READ ERRORS box.
It will save you time otherwise you have to wait for along time. -
dragon, you are a absolute legend, i have spent 6 hours downloading every dvd ripping program in sefy's guide and searching the forums for answers to 2 files not being able to be ripped, and your message here worked, thank you so much
@8dragon8, I hope you don't mind, I borrowed (and given you credit of course) what you said to the Troubleshooting section in the upcoming 2.3 guide
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Try getting a DVD "Disc Doctor" or other tool to remove the scratches on the bottom of your DVD. They sell on the Internet for less than $30. I was able to fix some scratched DVD's with it and it removed some errors.
But then again, I could be wrong in my assumption.
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 02:49 -
DVD Pro Lab - Error: Read Data Size
By lapetite_66 in forum Authoring (DVD)Replies: 2Last Post: 23rd Jul 2009, 14:48 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
Read error on "good" DVD discs?
By jerrylynnb in forum RestorationReplies: 12Last Post: 28th Oct 2008, 06:06 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
