Recently I have been trying to convert MPEG2 video captured by my TV card and convert it to MPEG 1 for VCD purposes. I Used DVD2AVI to make d2v files/wav. When I converted those with TMPGenc, I found that it worked perfectly on my computer. But when I put it to a VCD and play it on my DVD player, it is Choppy on certain parts and always on the same parts. I know how to convert Divx and make VCDs that work great on my DVD but I found out recently that My roomate also converted a Divx file and that one does the same thing as the MPEG2. If I take one of the MPEG1 that I just converted from MPEG2 and recovert it the same way, it is less quality but works fine. But I want good quality. I took one of the good quality videos and played it on a Sony DVD with Progressive scan and it worked fine, but when I played it on a Panasonic (which is known for its compatabilty) it didn't. I need to know if I am converting them wrong, if my DVD player sucks, if my burner is screwing up the video cause it works on the PC, or if it is possible for a VCD to be too good a quality. And by the way, all of my old Divx converted VCD's still work, so why don't they now. I know this has been long a drawn out but I have done a lot to try and figure it out myself and I need HELP!!! Thank you.
This is an In-Short overall for what I said above:
Im converting mpeg2 to vcd mpeg1 and it works great on the PC but sucks on the DVD player. I know I am doing this right cause all of my older Divx to VCD work fine on my player. Why is it Choppy on the player is all I want to know so I can fix it!!!!
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 16:05
