I have been trying to encode a Divx .avi file in Ulead Movie Factory 2 and have been gettin audio sync problems.
Everything will look and sound great until about 3/4 of the way through the show and then the audio will be WAY out of sync. In the MPEG settings, I chose Mpeg audio instead of LPCM. Would this make a difference?
I tried encoding it in TMPGenc first, then burning with MF2, but it kept trying to re-encode the file before burning, so I decided to just try to let MF2 do it all. It looked like this was going to work great (fairly fast and very easy), but on each of the shows I tried authoring, the audio sync issue showed up about 3/4 of the way through.
Thanks for all advice.
Results 1 to 1 of 1
I have a problem using Ulead DVD Movie factory including.AVI Files, the pro
By OggO1984 in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2009, 08:42 -
Ulead dvd movie factory keeps re encoding my files?
By kingsley in forum Authoring (DVD)Replies: 9Last Post: 4th Jun 2008, 12:26 -
190Mb movie file NEED it smaller -4 Mb. Encoding issue?
By famreeks in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2008, 07:06 -
Problem with HD movie (avi) file
By DarkArcher in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2007, 04:18 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 03:26
