i havevanilla sky on 2 cd's and i want to put them on vcd ,when i want to convert cd 1 the file is 712.150ko no problem it fits on a 80min cd ;after the converting the file is 1.099.780 ,it fits no more on a cd of 80 minutes ,i use tmpgenc ,yesterday i allready asked the question and somebody said to me i needed to load the approriate template,where can i find them or what most i do and he also said to me if i used the standard bitrate for vcd ,can somebody please explain this,sorry for my bad english ,thanks
Try reading some of the guides on this site. This one should help for starters: https://www.videohelp.com/tmpgenc.htm
Also take a look in the user gudies forum for info on how to handle VBR audio with virtualdub and TmpGenc as I think that may be part of your problem. -
Sometimes you can get it to 'shrink' if you extract audio from AVI file with VDub and then encode to MPG using AVI for video and new audio file for audio in TMPGEnc.
Chapters to DivX Movie ?
By PowerFalcon in forum Video ConversionReplies: 6Last Post: 3rd Nov 2011, 19:15 -
DivX Movie Playing
By ghforlife in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2009, 11:38 -
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 11:43 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 15:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 04:41
