Can anyone please help me?
I have downloaded an avi file of the ring,when i play it in mediaplayer there is picture but no sound.I installed nimo5 then there was sound but the picture was all screwed up.I unistalled nimo5 and installed ac3 codec,the sound and picture are now running slow as if in slowmo.Is there a special codec i need?Please help,Ryan.
Try uninstall all your codecs and install K-Lite Codec Pack 1.6 which you can get from here http://doa2.host.sk/ in the download section.
Rear projection HD tv picture fault
By Stedalton in forum DVB / IPTVReplies: 0Last Post: 22nd Jun 2010, 13:16 -
ipod 160gig screen fault?
By angryassdrummer in forum Portable VideoReplies: 0Last Post: 7th Jul 2009, 00:45 -
Car radio fault
By didikai in forum Off topicReplies: 2Last Post: 26th Oct 2008, 17:17 -
Segmentation fault while executing dvdauthor
By mmasroorali in forum Authoring (DVD)Replies: 3Last Post: 17th Oct 2008, 19:33 -
fault on toshiba rd-xs24
By superray in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Dec 2007, 07:31
