    Nov 2002
    netherlands
    hi guys.. i've downloaded a bunch of video clips (Svcd) all of them are ntsc and since my tv does not suppurt that i had to convert them to PAL mpeg's.. i converted it with tmpg inc. but when its done i get no sound what so ever... and when i try opening that same file with tpmg it says that sound is in the file so im a little confused.. maybe it's my codec.. got too much installed on my hd anyway hehe can anyone give me an suggestion.. thnx
    ciao
    Sep 2001
    Japan
    Use tmpgenc to demux (under mpeg-tools) your file.If you can play the audio (winamp is fine), than something's wrong with your playback.Otherwise you should extract the audio before converting to PAL and alter speed (30->25 fps) with any avail. AudioEditor (for ex. CoolEdit).
