Hey All,
Hope everyone's great.
I sent a not along to DJRumpy to on this topic, but I also wanted to see if anyone else had had any similar experiences.
I have authored up a few full projects in Maestro. They have all been rendered out, to their respective aud / vid TS ddirectories.
From here, I have been using Nero to burn out the files in UDF 102.
To test these clips prior to burning them out, I load the IFO into my DVD player. The movies and buttons all play and behave perfectly.
However, after burning in Nero, half of the buttons will not work. So Nero appears to not be burning what it is given correctly.
The buttons that worked on the hard drive version work, on the drive only, but not once those same files are transferred to DVDR, they do not.
Could this be just the media used ????? Or does anyone have any other clues. I was using KHypermedia discs. Dare I try it as a Data CD in Roxio EZ CD CR 6 ?!?! Or I also have Prassi Primo DVD v 2.5, however it will not let me pick my DVR 105 for the recorder ?!?!?!
Thanks everyone for any help
~S~
Results 1 to 13 of 13
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Spidey,
Hope this isn't a dumb question but did you assign all the buttons in Maestro? I burned 2 coasters before I realized I had not assigned actions for each buttons. I also tried the video_ts folder with my Windvd and it played perfectly. But ofcourse it didn't work on the standalones. I'm not a fan of nero, but I would bet it is probably an authoring issue rather then burning. Just a thought. -
Dunno why with NERO:
did you do both DVD VIDEO and DVD DATA (UDF 1.02) burns?
But here PRASSI will recognize your drive:
The Px Engine update provides product updates, fixes, and new CD and DVD recorder support. Use this download to update these products.
RecordNow, RecordNow DX, & RecordNow Max
MyCD & MyCD Pro
PrimoCD & PrimoCD Plus, PrimoCD Pro8, PrimoCD Pro16, PrimoCD Pro64 & PrimoDVD
Click'N Burn Plus & Click'N Burn Pro
SonicBurn, CD Extreme, Spressa Play & Record http://www.prassieurope.com/ -
You can properly assign the buttons in Maestro, and the result will work in a computer DVD player because you can move the mouse pointer over the button. My guess is that you didn't assign any button navigation to the individual buttons so that you could use the cursor keypad, or buttons on your DVD player's remote.
Go to the BUTTONS panel in your menu screens, highlight the first button, then assign the next button for cursor movement. -
Oh, one more thing... NERO doesn't affect the buttons at all. It just burns what you have compiled.
Hi Guys,
Thanks for the replies. I do agree totally with everyone said. However, I did do all the button mapping. That's where I was totally stumped. To ensure it was following it, I did not even use the mouse to navigate but the button pad......
I burned out the exact same files now in Prassi, and guess what it worked like a charm
So it had to be Nero. In talking to DJRumpy, he had said that if you do not have the exact image fixed in your background / top layer of your overlay, Nero will not transfer that type of routing, even though it's authored into the disc's compilation.
That's all I can see as the issue, since I used Prassi on the same files, and it came out perfect. The only difference between the 2 burns, obviously is the burning program, but I used a Khypermedia on the Nero, and a Princo on the Prassi Primo. I can't think the media could've screwed up the button's functions, but that is the only other differeing factor.
If anyone has more ideas, I'd love to hear them. Thanks guys
~S~~~~Spidey~~~
How did PRASSI use your PIONEER DRIVE?
Did it require the upgrade.?
I'm asking, because the upgrade went well on one machine, but the other still doesn't see the drive (A-04 here at work),
but I still am recommending the upgrade -
Hi Bud,
The project that I have burnt out I did without installing the upgrade. The other version of Prassi I'd gotten, I think v 2.089, did see my DVR 105, while my original 2.5 did not.
I did do the upgrade late last night, but haven't checked it again since doing so.
It's safe to say I hope it does see it though !!!! LOL !!!!!
Also, I had another question, in Prassi, when you add your video and audio TS directories to burn out, can you add another directory in the dvd's root to store jpg's etc ? Or will that mess it up ?
i.e.
DVD Root
\VIDEO_TS\ disc contents
\AUDIO_TS\ 'empty'
\INFO\ jpgs, txts, etc....
Thanks and hope you're having a great one !!!!
~S~~~~Spidey~~~
The only way I've been able to ad non-dvd content is to use NERO and Ignore the system prompts about an unplayable disc..
That is you need to know what you're doing specifically won't screw things up! -when you add these items...
I not sure I remember it corrrectly, but I think PRASSI just wouldn't burn when addded material was there
SPRUCE UP has a button in the BURN & CREATE dialog that allows you to add a seperate folder of "DVD-ROM" content..but I haven't used that one either
Specifically, I've encountered Nero's message when my VIDEO_TS's had extra files from the authoring program (SPRUCEUP)that weren't strictly "SPEC" but these DVD's always play in SETTOPS and COMPUTER hen burned DVD-UDF in NERO.. -
I'll check more into it. I knew Nero would allow it as I did it on all my SVCD's, ....
Thanks again very much
Hope all is good in NYC. I have a Bro up at Hofstra and we were up there visting this past Nov
It's damn expensive to drink in the city !!!!!
Thanks again
~S~~~~Spidey~~~
It did not like the addition of that extra "info" dir at all
It really tanked the disc, so it looks like I have a coaster to use for the weekend
Cheers all
Have a great one
~~~Spidey~~~
So back to the initial
"NERO is a ZERO"
by the way is it 5.5.17? or HIGHER (i hear .19 is out)
but mostly -I've heard 5.5.10 and less is ng for DVD creation -
that's interesting. my first bad burn I originally spoke of was using 5.5.10.0 since then I upgraded to 5.5.10.15a
but who can keep up with them.......
Plus, my goal is to just simply find a method that works, and unless Nero wishes to pay me for the coasters it's creating, I'd prefer to not take a chance as to will this revision work, or maybe this one, etc.....
The Prassi is working extremely well, so I think I may stick with it.
Hope all's great with you Bud. Survive the snow
~S~~~~Spidey~~~
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
