Hello. I read somewhere that people were getting 6x or 8x read speeds using the DRU500A and the latest firmware upgrade. But using DVD Decrypter i can only get my dvd's to read at 2x. Does anyone know a fix to this so i can make my read speeds faster? If so could you please detail how i would go about changing my settings? Thanks!
It may be doing that but perhaps only on two layer DVD's. Try a single layer DVD and see what the read is. DVD drives are so cheap these days I just bought one for ripping only and use my Sony for burning only..
I've tried both a dual-layer dvd and a dvd that i burned myself and both only rip at 2x. Also about the getting another dvd-drive to just read the disks. i read somewhere that there was a compatiblity issue with having more than 1 dvd drive hooked up when the dru500a is present. is this true? will i have compatibilty problems if i hook another dvd player up to my computer? sorry for all the questions but some help on this would be greatly appreciated! thanks!
I'm not having any compatibility issues and I have three drives on this computer.
Try an original DVD single layer disc not one you burned. I remember reading where the read was slower on dual layer and DVD+/- media. I use SmartRipper and see speeds of 8 to 14x for single layer DVDs and 4 to 8x on dual layer DVDs. If I try to rip from the Sony my speed is also 2x but I'm not sure if I was using a single or dual layer DVD when I tried that. -
I'm pretty sure the DRU500a can only read data dvd at 4x and video at 2x...so it's REALLY damn slow to rip a video dvd using this drive. I'd *HIGHLY* recommend getting a 16x DVD-ROM drive to do this as u will easily save about 10-15 mins/rip for only like $30 or so. (Plus u could always do disc to disc if ur computer is fast enuff and ur dma settings are cherry once u have that dvdr of the dvd video). THe only real downside is losing one of ur IDE connections of ur precious 4 (which basically leaves only *one* since u have ur hdd, the dvd burner and the dvd-rom)
HL-DT-ST DVDRAM GSA-T20N read speed too slow!!
By tmangia in forum DVD & Blu-ray WritersReplies: 10Last Post: 17th Aug 2010, 05:44 -
DVD Burner sudenly read/writes at less than 1x speed
By Megahurts in forum ComputerReplies: 1Last Post: 22nd Apr 2009, 21:47 -
Problems with LG GH22LS30 Read speed
By Clint Eastwood in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Dec 2008, 22:50 -
Any min read speed requirement for flash drive?
By larrym in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2008, 10:13 -
what is you highest read speed?
By wiak in forum DVD & Blu-ray WritersReplies: 8Last Post: 24th Jul 2007, 10:56
![Computer details: Windows XP Pro SP1
AMD Athlon XP2600+
5 x 120GB Western Digital 8MB Cache, 1 x 100GB Wes
1.5GB DDR PC2700
ATI AIW Radeon 8500DV
Sony Playstation 2, Sony DVP-530D
Sony DRU-500A [Firmware 1.0g]
Asus A7V-333R
Comp](/images/buttons/computer.gif)
