Does it matter what program you use to capture video? For instance, is there a difference in video quality when captuing with vitualdub versus capturing with Adobe premier, or something else?
Say I capture a tv show and burn it to a DVD and later I decide I want to edit out the commercials. If I capture video off the DVD I burned and edit it, when I burn it onto a new DVD will the quality be worse?
Sorry of these questions have been asked before. I tried searching through the message boards but there's so much.
You will need to use a program that can cut VOB files without re-encoding or one that can demux the vobs and remux as standard Mpeg2 program stream, then cut with an mpeg cutter. This task will be made easier by using MP2 audio or even perhaps WAV, I'm not sure how easy it will be to slice VOBS with AC3 audio. I'm sure this has been discussed here before, maybe a search will bring something up.
Questions about video re-encoding and downscaling - quality loss? bitrates?
By Veid in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 00:06 -
Newbie with a few questions re image quality
By okieman in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2011, 19:41 -
Rendering and Quality Questions?
By Boomer8404 in forum Newbie / General discussionsReplies: 0Last Post: 28th Sep 2010, 12:16 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 12:15
