I took a 55 min divx and converted it to mpeg 1 using
TMPGenc, using the 2 pass VBR template found on this website
(tools section).
Quality wise the result is great, it plays fine on the PC
but during fast movement it gets jerky on the TV.
Do you think the cause for this problem could be that the
original DivX uses 23.97 FPS and the converted MPEG 25 FPS?
Reason i used 25 FPS is cause the template for 2 pass VBR
defaulted to 25 (also defaults to PAL but i changed that to
NTSC).
I don't usually have problems playing VCDs/SVCDs on my
DVD player (Pioneer Dv-343), this is my first divx to vcd
attempt
Any clues on what might cause the choppy playback on fast
action scenes on the TV but not the PC would be appreciated.
If you use to play with an NTSC DVD player you will have to use 3-2 pulldown to make it play at 29.97 FPS
Pioneer can not play at diferent fps then 29.97
Some players can play diferent FPS but not Pioneer.
So...you can youe that template but change with 23.976 FPS and use NTSC and 3-2 pulldown option.
That's it.
Good Luck.
Catman -
altoids666
Thats complete bullshit. I have a Pioneer 535 and it can play VBR VCD's.
Try this to encode vcd's
settings using DVD2AVI and TMPEGenc.
Use the following.
I use cladDVD 1.70 to rip the movie files only from the DVD.
Then I open DVD2AVI and use the following settings
Video: iDCT Algorithm - IEEE-1180 reference
Field Operation - Forced Film
Color Space - YUV
YUV > RGB - TV Scale
Audio: Track Number - 1
Channel Format - Dolby Digital
Dolby Digital - Decode
Then save project.
Open up project .dv file with TMPEGenc.
Video Setting
Stream Type- MPG1
Size 352 x 240
Aspect Ratio - 4.3 525 line NTSC
Frame Rate 29.97
Rate control mode - Automatic
Motion Search Procision - Highest Quality
ADVANCED tab
Video Source Type - Non-Interlace
Field order - Bottom field first
Source Aspect Ratio - 16:9 for wide screen / 4:3 for full screen
Video Arrange method - No Margin (Keep Aspect)
QUARTIERIZE MATRIX tab
Put checks in the
Output YUV data
Use floating point DCT
No hit the ENCODE Button
I use a VBR at 29.97 NTSC 16:9 Aspect and it comes out
perfect.
DIVX Conversion
If you want to use 25 FPS then you have to change the template to PAL for it to work on your standalone. Thats your problem here.
Doesn't matter If it play VCD it will play both formats Pal or NTSC.
how about sony dvp330?
anyone out there to help me settings with choppy playback?
Thanks -
Going from 23.976fps to 25fps gives choppy/jerky playback. Solutions are sticking to 23.976fps since most players support that or if you really need 25fps speed it up like this:
Open the 23.976fps source in VirtualDub. Save the audio as uncompressed wav. Save the video with direct stream copy and change the frame rate to 25fps. Durations of video and audio will differ now. Use Cool Edit 2000 to speed audio up to match duration of video.
Regards,
Willem
Playback of AVCHD on Bly Ray Player Choppy
By andy90 in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Sep 2011, 23:30 -
Xvid AC3 file playback problem on Standalone DVD player
By kamol88 in forum Video ConversionReplies: 2Last Post: 21st Mar 2009, 03:38 -
MSWMM playback on standalone dvd player
By theyr961 in forum Newbie / General discussionsReplies: 2Last Post: 21st Feb 2009, 19:55 -
Some XviDs play choppy on standalone DVD player, but absolutely fine on PC
By udaykhan in forum DVD RippingReplies: 5Last Post: 15th Jan 2008, 11:09 -
CD/DVD playback on standalone player is smaller than TV screen...
By xiduk in forum Newbie / General discussionsReplies: 5Last Post: 1st Nov 2007, 17:02
