I have a DivX AVI. I have saved the uncompressed WAV with Virtualdub. (also cheked AVI for bad frames)
When converting to MPG with TMPGenc with toolame my PC freezes about 30% of the way. I've also tried using the TMPGenc internal Audio engine .. same problem
Then tried with MainConcept . same thing. Tried on another PC ..same thing.
Any Ideas ?
Maybe the title of your post is a bit misleading. It is obvious that this is not a toolame or TmpGenc problem.
About the only thing I can think of is your avi still has bad frames. You say you scanned it for bad frames with vdub. I assume you the set audio and video to direct stream copy and save out a new copy of the avi? In this case it may be that vdub has 'missed' some problem. I suggest searching the forum and looking to the user guides for more info on removing bad frames manually as, although vdub does a pretty good job it is not perfect.
program freeze
By mulgui in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2009, 22:03 -
mplayer freeze
By ajv in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2009, 17:15 -
Svcd2dvd Freeze's
By gazinc in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 18th Apr 2008, 14:00 -
pc freeze up
By triggerstep in forum Video ConversionReplies: 5Last Post: 24th Feb 2008, 05:12 -
my computer freeze all the time
By ieh4f in forum ComputerReplies: 13Last Post: 24th May 2007, 12:50
