I am having a Problem using "TMPGEnc Plus". I Ripped from a DVD that is
2hrs 5mins. using "Clad XP' then "DVD2AVI". That went well, but when I tried to use "TMPGEnc, it said it couldn't read d2v or unsupported. I tried to load all the Codecs I could, but no luck. Do I need to change my settings in "DVD2AVI"?, or can someone tell me the exact Codec I Need?
Thanks In Advance...
If you get an error message when opening like file unsupported or can not open or is not supported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Try first to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
Hope That Helps!!!:P
Thanks you, for your reply. I tried that a few times, but it still didn't work...
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46
