hello all can you help me please. just reinstalled xp on my cumputer, ive got to drives both about 60gigs,but since installing xp only one showing. both showing before. any ideas.
Is one of the drives new?
Did you check then RE check the slave & or master settings?
Did you hook the power cord to it?
My new HD was weird. The pin settings were totally different than my last one.
Do you have another machine to test it on?
Why did you reinstall XP?Don't give in to DVD2ONE, that leads to the dark side. -
There could be a ton of possibilities..
what are you using?
ATA, EIDE, IDE, SCSI?
Did u configure the drive properly during reinstall?
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
