Got the Sony DRU 500AX today have not tried it yet as it did not fit in my pc because of large dvd tray and my case having a plastic moulded front took me 3 hours to get it to fit . the firmware is 2.0c is this normal the build date on the drive is january 2003
Some questions
1 is this firmware normal and the latest
2 does the drive write automatically to whatever media you put in(dvd-r dvd+r)
3 this came with it which should i use
RECORDNOW DX
DLA
SIMPLE BACKUP
MUSICMATCH JUKEBOX
MYDVD
POWERDVD
Normally i use windvd
normally i use winamp
so that would rule out musicmatch jukebox and power dvd
what about the rest
i also have prassi primo 2 is it better than recordnow dx or would the retail recordnow max be better still
i know this is a lot of questions but if i ask them all over the place i wont find them so feel free to answer any or all if your an expert
thanks
Here is the support link for your drive. It will have the updates for your drive when the come available. You are now at the latest firmware version.
http://sony.storagesupport.com/dvdrw/dru500axdwn.htm
Yes.
RECORDNOW DX
DLA
SIMPLE BACKUP
MUSICMATCH JUKEBOX
MYDVD
POWERDVD
I wouldn't use any of it except maybe PowerDVD. What you have is better.
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
By mek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2010, 14:35 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 18:45 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
