I have yet to make a DVD that will play on this. Every attempt has failed, all but one with the same results. Once I got a "the disk is dirty" error, every other time it sees the disk, illuminates the DVD light and then switches to the nest disk. I am using a Pioneer DVR-105 with the DVD-RW that was packaged with it and Memorex DVD-R's. I have tried a bunch of different software to write the disk. Many webpages say that the player is compatible with DVD-r's. Has anybody had any luck with this player and if so what software and media?
Results 1 to 12 of 12
https://www.videohelp.com/dvdplayers.php?DVDname=NC600&Search=Search&Submit2=Search
Well this link says that player will read DVD-R and DVD+R. You are putting all the DVD files in a "VIDEO_TS floder and then burning that folder? Also I assume you are closing or finalizing the DVD if not it will not work. -
Yes putting all in Video_TS and Audio_TS, I am finalizing. I have even burned direct from ulead movie workshop 1.3 thinking maybe I wasn't putting the right folders on. All dvd's except the one that gave the dirty disk error do play in my KLH HA7000. I have tried Nero (dvd video, dvd udf 1.02, etc, etc, etc) nothing seems to work.
Looking at users comments on the player it seems it does have problems with DVD-R so take a look yourself.
https://www.videohelp.com/dvdplayers.php?DVDnameid=889&Search=Search&#comments -
I had read those before, realize that not all are getting the dvd-r's to play, but if anybody is, than it is possible. That said, I was hoping that somebody who had accomplished it could share the secret.
I seem to remember that if you record the DVD using "UDF" (I think that's right) it will play in most players. I believe this is an option with some burning programs like RecordNow Max.
Why don't you experiment using a DVD-RW disc? That way you don't waste any media trying to figure out the problem.
Other than one attempt with a dvd-r (to rule out the -rw disk as the cause) all have been on a dvd-rw.
Well you're one step ahead of me.
BTW if you're in the states BestBuy sells this cheap DVD player the Mintek model 1600 for around $50 that will play anything you throw at it including un-authored mpeg2, VCD, and SVCD. I bought three of them for family members so they could share my movies. -
Well, I would do that except my electronics collection seems to keep growing and my wife complains that everytime she gets used to how things work, I change it. S I am hoping to get them to work on the Sony. If not, I guess I just watch the shows I record in my bedroom on the LKH.
I understand completely. My solution was to get rid of the wife but I'm not suggesting you do the same.Originally Posted by bigw25
Sony DVP-NC600 Multi-region question
By kc7gr in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Dec 2014, 23:44 -
Sony dvp-sr100
By deyangg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2011, 04:54 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2010, 00:56 -
Multizone code for Sony DVP-NC600
By moamoa in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Feb 2008, 18:19 -
HELP !!! Please !! Sony DVP-S7700
By adamsj13 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Oct 2007, 05:04
