Hi![]()
I've got some films xvid/ac3, run them through v-dub (mp3 freeze). Deleted the bad frames and saved a direct stream. Extracted the audio
and saved to wav. Then run this through tmpg, and still the film is out of sync. If I try to put the audio through headac3he to convert to ac3 the program can't find chunk, if I try to change the file name it becomes unstable???????
any ideas kb
Results 1 to 9 of 9
Originally Posted by k b
Hi bugster
Did what you said, now the headac3he is recognising it but it will not load. It comes up with the dialog box "could not find data chunk"
Have you got any idea why?
many thanks kb -
hi
Should have mentioned that I'm converting to pal, mpg 1- vcd.
Also where you change the bitrate in tmpg,can't seem too change
the rate to best quality? It just does not come active the drop down box!
Any more advice
Many thanks kb -
Hi bugster
Tried to load the settings, from the template, extra folder, but the dialog box comes up illegal stream format?
many thank kb -
Ok try this. 1st load the VCD template (load and select the PAL VCD template). Then click load again and load the unlock template. This should allow you to mess with settings all you want, but from a know starting point.
Hi
Still can't sort out the problem, load the templets and still it stays the same. If I could only find a way to load the wav file into headac3he and convert I think the audio would be in sync,I think when the file in v-dub
saves as wav it's still ac3 could this be so?
Any more ideas
many thanks so far fro your imput
kb
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 09:49 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 15:00 -
wmcapture sync problems?
By the_doc735 in forum Video Streaming DownloadingReplies: 2Last Post: 6th Apr 2009, 15:32 -
Audio sync problems
By sticklebrick in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2007, 14:14 -
Time sync problems.
By Poppa_Meth in forum ComputerReplies: 9Last Post: 1st Sep 2007, 00:30
