Just been to Walmart's website and saw this Panasonic
http://www.walmart.com/catalog/product.gsp?product_id=2073242&cat=95987&type=19&dept=3...105704%3A95987
there, supposed to be a new model but it's not on Panasonic's site...![]()
Anyway, anyone seen or bought it? Any info would be nice.
Thanx.
Found this on Panasonic's Website. I want to know if it plays SVCD's. I went to Circuit City and put one of my SVCD's in it (TMPGEnc) and it looked like it was playing, (screen said play, but VCD), but they don't have any hooked up to a monitor...
cut here
DVD-S35K
Progressive-Scan DVD-Video Player with DVD-RAM/R, CD-R/RW, MP3, WMA and JPEG Playback
MSRP $99.95
Playable Disc Type DVD-Video, DVD-RAM, DVD-R, Video CD, CD, CD-R, CD-RW
DVD-RAM Video Playback Capability Yes
DVD-R Playback 1 Capability Yes
CD-R/RW Playback 2 Yes
MP3 Playback 3 Capability Yes
WMA (Windows Media Audio) Playback Capability Yes
Progressive Scanning Yes
Video D/A Converter 54MHz/10-bit
4:4:4 Signal Processing Yes
4:3 Shrink Function w/ Letterbox Zoom & Shift Yes
MPEG Digital Noise Reduction (Mosquito/Block/3D) No View all models with this feature
Zoom Variable (with dial)
Picture Control Brightness, Color, Contrast, Gamma Correction, Sharpness
Monitor Select No View all models with this feature
Auto Switching Field/Frame Still Yes
Frame Advance (Forward & Reverse) Yes
Black Level Control Yes
A-B-C-D Features No View all models with this feature
Advanced Surround (V.S.S.) Yes
Bass Plus No View all models with this feature
Cinema Mode Yes
Dialogue Enhancer Yes
Audio D/A Converter 192kHz/24-bit
Audio Only Function (Video Circuit OFF) No View all models with this feature
Built-in DTS® Surround Sound Decoder No
Built-in Dolby Digital® Surround Sound Decoder No
Optical Digital Output for DTS® & Dolby Digital® Surround Sound Yes
Headphone Surround (V.S.S.) Yes
Headphone Jack with Volume Control No
Dynamic Range Compression Yes
Direct Navigator Yes
Playlist Playback Yes
Hi Speed Smooth Scan 5 Speed up to x200
Progress Indicator Yes
Quick Replay Yes
Position Memory up to 5 discs
Sleep Timer Yes
Quick Guide Setup Yes
Audio Navigation Menu No
Audio/JPEG Navigation Menu Yes
Chapter Preview Yes
Twin Laser Pickup Yes
On-Screen Menu Icons Yes
Remote Control Standard
Energy Star® Compliant Yes
Progressive Video Out (Y, PB, PR) Yes
Component Video Out (Y, PB, PR) Switchable (480P/480I)
S-Video Out Yes
Video Out Yes
5.1ch Surround Sound Audio Out No
Subwoofer Out No
2ch Audio Out Yes
Digital Audio Out Optical
Headphone Out Yes
Video S/N 65 dB
Audio S/N 115 dB
Frequency Response: DVD-Video (fs 96kHz) 4Hz - 44kHz
Frequency Response: CD/Video CD (44.1kHz) 4Hz - 20kHz
Dynamic Range: DVD-Video (LPCM) 100dB
Dynamic Range: CD 98dB
Total Harmonic Distortion (CD) 0.0025%
Power Source AC 120V, 60Hz
Power Consumption 14W
Horizontal Resolution More than 500 lines
Model Type Single-Disc Player
5-Disc Rotary Changer No
5-Disc Changer Features No
Model Color Black
Still Picture Display (I/P/B) Yes
Shuttle Dial Yes
Dimensions (H x W x D) 23/8" x 1615/16" x 101/2"
Weight 4.7 lbs
footnotes:
1 This unit can play back Panasonic DVD-R discs recorded and finalized with a Panasonic DVD video recorder. It may not be able to play some DVD-R discs depending on the disc and the condition of the recording.
2 Plays CD-DA format audio CD-R and CD-RW discs. May not be able to play some CD-R or CD-RW discs due to the condition of the recording.
3 For contents recorded on CD-R/RW media from CDs for your personal use. Playability may vary depending on contents and discs.
NE1 use a Canon XA10? Need help with setting exposure w/ 18% grey card
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Jul 2012, 09:46 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15 -
NE1 here use GEARP.M.E. w/ Encore CS3 projects?
By sdsumike619 in forum Authoring (DVD)Replies: 1Last Post: 11th Aug 2008, 11:47 -
Can't read DVD-R with my Panasonic DVD-S35
By f_k_ng in forum DVD & Blu-ray PlayersReplies: 12Last Post: 1st Mar 2008, 02:44 -
Vertical Stretch on PAL playback on Panasonic DVD-S35 Player
By dennis albright in forum Video ConversionReplies: 5Last Post: 31st May 2007, 08:36
