Hi,
I have been looking all over the place looking for the file to add to TMPGEnc in order to open up wmv files and convert to vcd. Anyone have a ideal where to find this file.
Max142
you don't have to add anything. Just select "all files" on the opening tab when you go to open a file, and select your favourite WMV file to encode, and the program will continue normally from there.Originally Posted by max142
-MPB/AZ -
well I have tried that but after selecting all files and then highlight my wmv file to open, I get a screen that says that file cannot open/ unsupported. For some reason I was thinking that there was a file on this website to load in the program folder to open wmv files.
Should converting a mov file to wmv be so small?
By abrand88 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2010, 13:47 -
Help with converting from WMV to DV-AVI file..
By littlepipit in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 06:06 -
Problem converting .wmv file
By AdamUK in forum MacReplies: 3Last Post: 24th Apr 2008, 07:40 -
Converting (Quicktime) .MOV file to .WMV file
By stanislawski in forum Video ConversionReplies: 2Last Post: 6th Feb 2008, 18:19 -
Converting an ASF (WMV) file
By yadda in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 06:16
