  1. This is the best program out for authoring svcd.
    http://www.ttool.de/indexe.htm (TSVC's authors site)
    I have made some video tutorials, noted below.
    Tutorial 1 is 40 meg, 20 minutes, 1024 x 768 screen capture with audio.
    Tutorial 1 is 10 meg, 5 minutes, 1024 x 768 screen capture with audio.
    63.193.150.67
    login: tscv
    pass: tutorial
    port: 21
    4 logins max
    1 per ip
    The tutorials are rars in 1 meg chuncks.
    Get the codec 4.1 and support files from
    http://www.divx.com/
    and here at the download section
    PS. My bandwidth is very limited. If you find the tutorials help you, then please share them. Thanks
    Tutorials 3 and 4 coming soon.
    <font size=-1>[ This Message was edited by: legman on 2001-09-08 11:40:43 ]</font>
  2. Many downloads. How about a comment from someone that has seen it. I have plans to make the next ones much better. I chose the wrong codec to cap with and it made editing it a bitch. The next ones will be edited to save space buy cutting out my mistakes, lol
    Let me know what you think.
  3. here is another link that someone was kind enough to provide,
    http://www.edensrising.com/legman
  4. Tutorial 3 is now available.
    63.193.150.67
    login: tscv
    pass: tutorial
    port: 21
    This tutorial comes with a small read me file. Make sure you read it. It may clear up some areas of confusion. It is 10 meg in size, screen capped at 1014 x 768. and is 7 minutes long.
    This covers adding intro, extro, motion background, motion thumbnails, scrolling text, setting the chapter points, adding to new menu, updating the gui to work correctly with adding the new menu and of course….ALL the settings need for this to play back and work nicely.
    Also included in the tutorial 3 folder is the actual bin and cue file created. This is about 40 meg on it’s own, It is a tested image that works well. Please download this if you really need to burn it and test your player or are very confused or are desperate and can not comprehend how all this is suppose to work, Please do not download it unless very necessary, as my bandwidth is very limited.
    I ask you all again, to please share these files with your friends and make your own mirrors and distribute them as much as possible.
    Please provide me with feedback as the whether or not it has helped you or anyone else, as well as suggestions and ideas.
    Thank you,
    Legman
    PS> If the server is offline, then my wife is on the box using the bandwidth. The server will be back up, in this case, within an hour or 2.
  5. I just thought i would say thanks since i am downloading tutorial 3, hope i can learn something. Thanks for putting this up for us all to download, i will give some feedback after watching it.
    thx again
