I emailed ArcSoft tech support over a month ago, to ask a simple question: Is there a way to save the file (when clicking on Make Movie) as DVD, but not at 720x480? I want to save the file as 352x240.
I received a reply that said they would contact me within 2 days. It's now been over a month and I've resubmitted the question at least 5 times.
Does anyone know the answer?
Borg
You can save the movie as DVD but click settings, choose 'File Type' MPG2, then 352X240 then save. You will have to change the audio sampling rate of the MPEG file to 48k to be DVD compliant.
I know of no easier way with this program.
Chas -
BorgQueen,
You can only adjust frame size NOT samplerate.
Also Arcsoft was bought by Sonic last year and they are no longer supporting ShowBiz. -
What I meant to say was the sampling rate of the encoded MPEG file will have to be changed to 48K. To do this, you will have to use another program such as TMPGEnc.
Chas
ArcSoft Showbiz DVD 2 Smart Rendering
By zulubase in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2009, 21:12 -
hauppauge hd pvr/arcsoft tme bitrate question
By romanticwarrior in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Jun 2009, 19:34 -
Transitions make static in Arcsoft Showbiz MPEG2
By Canopus Smoker in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2008, 22:10 -
Unanswered questions on processing and compressing DV-AVI
By sd_smoker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 40Last Post: 2nd Jul 2008, 16:31 -
ArcSoft ShowBiz Audio Problem
By KenOBrien in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2007, 06:29
