  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Stargate
    Dec 2002
    Scotland
    Use DVD decrypter or another DVD ripper to rip the movie to your harddisk drive and then use DVD2ONE to transcode it.
    Then just burn the "VIDEO_TS" folder onto a DVD using a program like RecordNow Max.
    Best Regards.
    Barry
    God's in his heaven... All's right with the world!
    Robert Browning (1812 - 1889)
  3. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Stargate
  4. Member wulf109's Avatar
    Jul 2002
    That's odd my copy of Stargate is single-sided dual-layer disk with both the theratrical and extended versions.
    Rip each side of the DVD to a separate directory. Re-number the vob's from VTS_01_1.VOB thru VTS_01_?.VOB. Just be sure you start side one as VTS_01_1.VOB. Put them all in one directory. Then DVD2ONE will see them as one long movie.
    Dec 2002
    Scotland
    wulf109's method won't work, the Vob-ids will be all messed up. go to this guide here on how to fix them http://ifoedit.wh.fr0zen.com/joinclip.html#joindbl...
    Best Regards.
    Barry
