I have an XviD encoded avi which I want to convert to mpeg1 to play it on my DVD. My problem, TMPGEnc refuses to open the avi file ("...can not open or unsupported") and CCE just produces a distorted output file (but gives no error message).
According to G-Spot the movie uses the XviD and the ac3 codec, which I have both installed on my system. The video has an aspect ratio of 1.818:1 @ 23.976fps. The file plays without problems on my system using WMP. I just can't convert it using TMPEnc/CCE.
Any ideas?
Thanks, bUR
Results 1 to 9 of 9
Try this..... it might help you...... D.C.
https://www.videohelp.com/forum/viewtopic.php?p=457446#457446" Check him for weapons..... no; he doesn't need 'm...... he IS a weapon. " -- Return of the Dragon. -
Yes, thanks. I figured it out myself in the meantime.
For those who might encounter the same problem:
I extracted the audio as ac3 using virtualdub, then converted it to wav using headAC3. Then I frameserved the video using virtualdub to TMPGEnc and used the wav-file as the audio source. That worked perfectly. -
I have the same probolem, but I cant open it in virtualdub either! But plays fine on wmp.
virtualdub flashes an error really fast, I think it says something along the lines of cannot find compressor xvid unknown.
tried nandub, and it wont even open, it says cannoy find vorbisfile.dllfree the world -
Try ffdshow - it solved all my XviD voes in one strike.
/Mats -
Just install it. No idea how it works or what it does, but it sure helped me with every problem I had with XviDs, even if I had every codec needed installed.
/Mats -
didnt help, still cant open in vdub, nandub, cce, tempeg. But plays fine in power dvd and wmp.
any idea, would like to convert to an svcd.free the world -
Go to https://www.videohelp.com/forum/viewtopic.php?t=147444&highlight=xvid. Look for a post by gifted_retard. Follow his link and his instructions. If you have a valid xvid file you can change it to a divx file which V-Dub and TMPG can handle. I believe there are at least 4 different Xvid codecs that you can use. If you don't have the right one installed, you may not be able to load the video into V-Dub or TMPG. If you change it instead to a Divx file, you should have no problem. 8)
lagarith avi to xvid avi - problem
By phpmysql348 in forum EditingReplies: 1Last Post: 23rd May 2008, 12:15 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57 -
Conv software (Nero, VSO..) closing down after entering AVI files! Help!!!!
By xxjustinukxx in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 02:51 -
Automated XVID to MPEG1?
By SevenNine in forum Video ConversionReplies: 3Last Post: 26th May 2007, 15:52
