In trying to convert to svcd, I first used virtual dub (per guide) then tried to add it to cce when I got the error message in cce "frame rate 29970/2000 is not supported" I am totally stuck and have been working for 4 days to try and burn a svcd. PLEASE HELP
CCE requires an exact frame rate that matches one of 23.976, 24, 25, 29.97, 30, 50, 59.94 or 60 and will accept no variations.
Your frame rate is approx 15fps which CCE rejects.
Changing the frame rate to say 30fps in VirtualDub will only have the effect of 'speeding up' the video and ofcourse the audio will be out of sync.
The best way to frameserve using AVISYNTH with the filter;
'ChangeFPS(25)' or 'ChangeFPS(29.97)'
this will keep the correct video speed and keep the audio in sync.
HDConvertToX keep getting "AVI files larger than 2000 MB" error
By jsbenson in forum Video ConversionReplies: 3Last Post: 4th Nov 2009, 22:20 -
HCenc "Invalid MPEG-2 Frame rate" error.
By Maikeru-sama in forum Video ConversionReplies: 24Last Post: 8th Jul 2008, 19:09 -
"Unsupported audio rate in file" Message in Premiere Pro CS3
By JustinBaker in forum AudioReplies: 2Last Post: 24th Mar 2008, 00:27 -
CCE keeps on trying to change my frame rate?
By friedtofublocks in forum Video ConversionReplies: 17Last Post: 14th Dec 2007, 06:21 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
