I have a lot of music videos that need to be remultiplexed as Non-Standard MPEG-1 VCD (otherwise they require a lot of autopadding when I burn them with VCDEasy).
Now, MPEG Tools is pretty easy to use....but when you have a few hundred videos to process, this gets very tedious. Is there something out there that I could just drop many mpegs on, and it would automatically remultiplex them?
For MPEG-1, I would recommend Tmpgenc. It's free and supports batch processing (as most programs). Also, in MPEG-1 streams it is as fast as any other encoder (or faster).
You open the first video, select the settings of your choice, (save them if you wish as a template), and then add the video in the batch. From that point on, you can select more source videos and add them to the batch.
(not drag'n'drop, but next best thing). Good thing is that you can run the batch in phases, interrupt, shutdown, restart and continue with the next file.
On a P3/1000MHz, expect 0.75 Realtime performance. On a P4/2.67GHz expect 2x realtime performance for VCD.The more I learn, the more I come to realize how little it is I know.
Software tools to batch convert the following (details inside)
By spycam in forum AudioReplies: 0Last Post: 3rd Sep 2011, 09:29 -
Batch Watermark Software for MAC?
By hd28qi in forum Video ConversionReplies: 0Last Post: 3rd Feb 2011, 16:55 -
software for fast batch encoding mpeg2 >> .flv
By chadwill in forum Video ConversionReplies: 2Last Post: 24th Aug 2009, 02:19 -
AVCHD to HDV batch conversion software freeware?
By jasonlava in forum Video ConversionReplies: 7Last Post: 27th May 2009, 09:35 -
DVD Authoring software with Batch author?
By love2learn in forum Authoring (DVD)Replies: 6Last Post: 16th Aug 2007, 10:20
