I use movie factory 1 and when I burn there are 7 steps it goes through.
The first 3 steps go so quick you cant read them. I know it goes through multiplexing then building dvd then finalizing vob's then burn I think.
For a full DVD it takes about 20 minutes to get to the burn stage does that mean it is re-encoding the video ir is that normal?
I use DVD Movie Factory 2 and I can tell when it's re-encoding when it says something like "Preparing Video" in the status bar. If it says that, then it takes about 4 hours for a 2 hour video before it ever gets to the burn stage. I would say if you are getting there in 20 minutes for a full DVD it is not re-encoding. In MF2, when it does not re-encode, it flys by the "Preparing Video" stage and next moves to the "Multiplexing Audio" stage.
I have had pretty good luck with it not re-encoding imported DVD-compliant MPEG's, except those from PowerVCR II. For some reason it wants to re-encode those every time.
Ulead DVD Movie Factory 6 Plus
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 12:22 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 03:48 -
Ulead dvd movie factory keeps re encoding my files?
By kingsley in forum Authoring (DVD)Replies: 9Last Post: 4th Jun 2008, 12:26 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
