I have the Panasonic E30. I also have the Panasonic RP82 which plays both DVD-R and also DVD-RAM. I need another Panasonic RP82 real bad but I think they are discontinued. Is there another like this model that can play back also the DVD-RAM? Thanks in advance.
There is the dvd-s35 retails $99.
the dvd-xp30 about $230
the dvd-xp50 about $250
and the dvd-rp91 about $350
Depending in when you bought the dmr-e30 you might be able to get a free dvd-s35, check the rebate promo section of www.panasonic.com.
All of the models are panasonic. My suggestion would be to buy a second dmr-e30. If its within your budget. -
Panasonic CP72 is identical as the RP82 it has the faroudja chip or whatever they call it. It's a 5 disc changer though and there is a $30 manufacturer rebate out for it. You can find them for around $190 after rebate. Check out crutchfield.com. These are IDENTICAL.
the rp82 and cp82 are the same - yes .. except for the changer , great machines ...
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 21:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 21:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15 -
Panasonic AY-DVM83MQ vs. Panasonic AY-DVM83PQ and AY-DVM80XJ question.
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Feb 2008, 13:37
