Hi.
Ive just convert an .avi to a .m2v and .wav with TEMPGenc to problem is that the .m2v file got a little to big 4.24 Gb and i compressed the wav file so much i dont think i can compress it more .wav into .ac3 with 112kb bitrate.So when i use Spruceup to convert the .m2v and .ac3 to some .vobs and stuff it cant be burned tried to use nero,instant cd/dvd and spruce Up.Any idea on what i should do?I dont want to run it in TMPGEnc again last time it took about 20 hours so.
Thanx for any help
/Doc
Perhaps split it into 2 discs using TMPGEnc with the MPEG Tools (split & merge)? Just a thought ...........
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776 -
I would compress the audio to MPEG-2 Layer II at 64kbps joint Stereo (with Tmpgenc).
Start Tmpgenc, Clear the input video and audio, select the WAV audio file, go to settings and select the lower bitrate.
People may disagree that MPEG-2 Layer II will have a low sound quality, but it doesn't. TMpgenc has a good quality audio compressor and is also fast. On a P3/1000 machine should take you something like 25 minuts for two hours of movie.The more I learn, the more I come to realize how little it is I know. -
Hi
Thanx for the answers.I encoded a new one with little lower bitrate not much and no audio and got a .m2v file thats 3,9 Gb witch is ok.I saved my old .wav and the tests i did i dont have any synch problems.Anyway thanx for ure suggestions.
/Doc
Question about Lynksys NAS200 and moving large amount of data to it.
By nzdreamer55 in forum ComputerReplies: 0Last Post: 9th Sep 2010, 10:09 -
Dumb question. What do i need to know to film large enough 4 a movie screen
By tenderloin in forum MacReplies: 14Last Post: 30th Aug 2009, 19:22 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 11:57 -
Newbie question about learning
By Tundra Trout in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 18:41 -
Newbie Help - Very Large AVI file to DVD
By Lebowski25 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 22:42
