I want to do some "in game" capturing on my PC. I DO NOT have a video card with any type of in/out built in. I DO have a nice Sony DV cam, which does allow me to get just about any type of video INTO the PC, using Premier (PC), or iMovie (Mac.)
What I wanted to know was if there is anyway for me to get the game action (or anything happening on the PC ) into the DV camera or even to my VCR? It would have to go from the PC via Firewire, as that is my only "OUT" capability. I could either record it directly to the DV tape, or into the VCR using the DV camera as a bridge (with converter cable.)
PC---->DV Camera--->(DV tape, or VCR with converter cable.)
Perhaps there is software that allows video out via Firwire?
Any ideas?
Thanks,
Jim
It is not easy to do but you might be able to make it work.
Essentially, you would need a program that captures what is going on on your screen. There is a program called Camstudio that allows you to do this. This program isn't perfect but it usually works.
After you have captured what is going on on your desktop, you would need to transfer it to a DV avi file. I believe that Virtualdub can do this. (Although I have had problems doing this myself). For vdub, you need to install a DV codec such as the Panasonic DV codec.
Once that you have a DV avi file, you can export the file, using DVIO or DVapp.
In summary, you need the following items:
1- Camstudio (freeware)
2- Virtualdub (freeware)
2- the Panasonic DV codec (free) or another DV codec installed
3- DVIO or DVapp (freewares) to export the type 2 DV avi file to your camcorder
4- DV out must be disabled on your camcorder's menu
I have never actually tried this. So I am not sure if it works but, in theory, these are the steps that you would neeed to do.
P.S. It might be easier just to get a TV out card.
Connect my camera to my pc: Dead FireWire port
By DJSPYDER in forum Newbie / General discussionsReplies: 15Last Post: 6th May 2011, 11:19 -
Problems using a Panasonic DV camera (NV-DS50) in my firewire
By Duck_Plumber in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 10th Apr 2010, 09:10 -
firewire camera but only have usb ports
By skullhero in forum MacReplies: 27Last Post: 16th Jun 2009, 20:40 -
DV Camera to DVD plus Firewire Card Help.
By Sikander in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2007, 14:35 -
Multiple camera firewire ports getting fried!
By tinapeg82 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 29th Aug 2007, 16:59
