Does anyone know how I can use ffmpegx to convert a mp2 file to an ac3? I for the life of me can't figure it out. Is it even possible? Thanks to anyone who can lend me a hand.
saltydog4791
off hand i'm not sure, but would going from mp2 to aiff or wave then to ac3 help???
pants on, pants off, pants the floor. -
that'll work too. basically I just need some way to do mp2 to ac3 all from the command line to include in a shell script that I am working on. there must be a way. windoze has besweet. what do we have? batch encoding in A.Pack stinks. it's not very convenient. I need something I can shell script. does anyone out there know the way?
saltydog4791 -
ffmpegx
video
assthrough video; deselect encode video
audio: AC3
Select file, run -
well, I have tried that and it didn't work for me, but I did do some investigating. I echoed the command line to see what the terminal was doing.
It would run the following command--
printf "Encoding started on " ; date ; /Applications/ffmpegX.app//Contents/Resources/ffmpeg -i /Volumes/XXXXXX/test.wav -y -vn -f ac3 -acodec ac3 -ab 192 -ar 48000 -ac 2 -map 0.1:0.0 -benchmark /Volumes/XXXXXX/test1.ac3 ; printf "Encoding completed on " ; date ; printf "\a\n"
This resulted in a bus error for some reason, but when I took out the -map 0.1:0.0 the encoding worked. Can anyone explain this map parameter because I don't understand what it is and why it would cause the command to fail.
I am getting close to figuring this thing out.
saltydog4791 -
Well, at least you did more than I would have been able to. I would have had no clue to delete -map out of the command.
That's pretty cool there.
Sorry! That didn't really answer any question!
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
AC3 Question
By Madz5 in forum AudioReplies: 17Last Post: 6th Dec 2010, 05:28 -
Question about 'AC3 Normalizer'
By sgbd in forum AudioReplies: 2Last Post: 20th Oct 2010, 20:35 -
Convert MP2 to AC3 within VOB structure
By Xesdeeni in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 14:19 -
AC3 or not AC3, that's my question!
By moviebuff2 in forum Newbie / General discussionsReplies: 4Last Post: 5th Jan 2008, 09:04
