  1. I realise that this unit is the OEM version of the dru-500a. Does it have the same specs as the latest firmware that is available for the dru-500a. For one does the dw-u10a support 4x burning of +R discs???
  2. Originally Posted by Falcon500
    hardware-wise, basically 100% same.
    software-wise, dw-u10a bundles none.
    firmware-wise, they're not the same and dw-u10a doesn't support 4x +R burning until you "upgrade" it to dru-500a with hacked firmware.
    price-wise, dw-u10a should be cheaper (not always).
  3. I have the dw-u10a and mine came with nero and powerdvd. There is now a patch available from www.firmware-flash.com that changes your dw-u10a into a u500a.
    Currently, as far as I know, there are 3 versions of firmware for the u10A -- 1.1a,1.1b and 1.1c. I have the 1.1a and have had no problems with it. I havent tried writing +R yet but it writes -R at 4x. Both the retial and oem will only read at 2x as far as I am aware.
    skooby
  4. Originally Posted by skooby
    those are retailer specific bundles. you don't get those most of the time.
  5. Hi,
    Whats the point in flashing the U10a with the hack for the 500a. The firmware for the 500a is lower than the U10a. The u 10 a is up to 1.1 isnt the 500a still in ver 1.0?
    If there are firmwares out for the u10a then you dont need to hack it to a 500a. Nero supports the drive you just need the latest version.
    John
  6. Originally Posted by mrspangle
    Hi,
    John
    Dont go by the numbers are sony are essentially treating them as 2 different drives and so have 2 different sets of firmware. As far as I am aware the 1.1c is equivalent to the 1.0g.
    You are correct about NERO supporting both drives (and hence the reason I have not bothered to flash mine from 1.1a), but other software, like prassi, does not support the u10a but does support the u500A.
    skooby
