I used the CALC tool here on site to determine bitrate for a 1hour 25 minute Show, The Lone Ranger Movie from WB. The Encoded film is 3.97gb. In Nero vision and EasyCD 6 both programs state the file is too big for the DVD.
What gives? if a dVD is 4.7gb why wouldnt a 4gb movie fit?
I have never used either of the programs you mention but my guess would be that they are converting the audio to PCM (uncompressed). Take a good look at all the options to see if they will allow you to use the mp2 audio in the encoded mpeg file (note that mp2 support is not required for NTSC region DVD players). If not try a different authoring package such as Ulead DVD Workshop or Movie factory. Demo's are available for download and both support mp2 audio in NTSC DVD's.
Hope this helps. -
downloaded ulead and it worked. I used the nero for a few other projects also and they worked. but I like Ulead so far.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 13:19 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 02:44 -
Improper joining?
By LWC in forum EditingReplies: 6Last Post: 21st Mar 2009, 19:58
