I looked around and can't find a how to on how to convert a DIVX file back to MPEG format to burn onto a DV+R..can someone help me..please..
Try this:
Go to the tools setion of this site and get virtualdub.
Start virtualdub and open your avi file with it. Then do the following
Audio->Full processing mode
Audio->compression - Non (PCM)
Audio->conversion (48khz if not alreday)
File->sav wav (name this movie.wav)
When this has finished you will have a movie.wav file that is probably larger than your original avi, thats normal. Close virtualdub
Open Tmpgenc and cancel the wizard.
For your video source, select the avi file. For your audio source, select the large wav file you just created with virtualdub.
For stream type select System (video+audio), name your output file movie.mpg
Now click load and select the DVD template. If the avi file is 23.976fps or 29.976 fps select the NTSC version. If it is 25fps select the PAL version.
Click START and Encode.
After doing the above work, import the MPG2 (large) file into DVD Movie Factory (or you favorite authoring software). Use DVDMF to author and burn the disc. -
Originally Posted by esanchez
https://www.videohelp.com/tmpgencdvd.htm
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 01:01 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
