I tried this in the newbie forum, but didn't get any responses, so I thought I would try it here.
I have been using virtualdub to extract the .wav file from a divx .avi file for ultimate conversion into a DVD .mpg file using TMPGenc. When using virtualdub, I change the sampling rate to 44100 Hz because I thought that was what the guide on this site said.
If this is going to be an MPEG-2 DVD .mpg file, should I have changed the sampling rate to 48000 Hz? The DVDs that I have burned have had some crackling and popping and some audio dropouts when I play them in my standalone DVD player. Could this have caused the audio problems?
Thanks,
Brian
yes, change to 48khz...you can use besweet to
change wav to an ac3 file, if you want, it must
be 48khz also...use spruce-up to rejoin and add
chapters.. -
<link removed - no warez>
A STEP BY STEP GUIDE TO ENCODING TO VCD/SVCD/DVD + ALL THE SOFTWARE DOWNLOADS YOU NEED TO COMPLETE THE ENCODING.
MANY THANKS
DIDIDAVE
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 08:12 -
.divx to .avi XviD conversion?
By Benhermies in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2009, 18:15 -
DIVX to AVI conversion
By jjbodean1970 in forum Video ConversionReplies: 9Last Post: 18th Aug 2008, 00:05 -
Framerate conversion question (AVI --> DVD)
By kmmoore in forum Video ConversionReplies: 3Last Post: 19th Oct 2007, 09:47 -
divx conversion question
By nagihcim1 in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2007, 17:20
