I was wondering if there was anyone out there that could have a solution for my freezing problems. Here is my process:
1. Rip main movie with Decrypter
2. Compress video with DVD2One (if needed)
3. Create image of VIDEO_TS and AUDIO_TS folders with ImgTools.
4. Burn with Decrypter at 1X speed
I've used RecordNowMax to burn as well as BUT the freezing is worse. I've been using both Princo (-R) and Ritek 1X media. My burner is a Toshiba SD5002 (2X).
The movies I burn do not freeze completely, just a bit, then they keep on playing. They freeze throughout the entire movie (really annoying). I've tried them in two different DVD standalones with the same results. I have a Toshiba SD-3750 and a Broksonic DVCR810 DVD Combo standalone. The freezes don’t come at chapter changes, they are just random. Could it be my process or the media? Help would greatly appreciated. Thanks!
Live Long, Play Hard, Think BIG!
I have noticed the same thing. Using Both nero and gear pro to burn Video_ts folders made with DVD I have noticed this @chapter points and at other random places.
It seems to be worse when the disk is hot (my imaginatio?) dunno.
What we have in common is that i also use princos and i have a Toshiba SD-3750. I'll have to go find some other Players to test on.
I had one disk that was so stuttering on chapter 4 start that i burned it agin same result! Well i waited a few hours and both thos disks play the chapter four start with no glitches. (must have been heat related)
I have other disks that are days old and do it randomly.
Freezing Problem!!!!!!!!
By vickynash in forum Newbie / General discussionsReplies: 20Last Post: 26th Jun 2010, 21:37 -
DVD freezing?
By XyBeRz in forum Authoring (DVD)Replies: 10Last Post: 28th Dec 2008, 23:26 -
Freezing DVD-R
By markannab in forum Authoring (DVD)Replies: 7Last Post: 3rd Feb 2008, 03:01 -
TEVION 8000 / 8001 HDMI DVD PLAYER problems with picture freezing....
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:56 -
Tevion 8001 HDMI DVD player - disc sticking/freezing problems.
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:50
