    Sep 2001
    N/A
    when instant copy deltes titles sets is it safe??? I mean does it cause any problems etc,.,
    Baker
    My vcd & cvdGuide
  2. IstantCopy does not delete titlesets unless you hack the registry. I stopped using the registry hack and let InstantCopy work as designed because I was having navigational issues.
  3. I tried InstantCopy only once removing the 'FBI Warning' clip (which is normally the 2nd clip played). When I went to play the DVD played the 1st then hung right where the FBI would have been, I assumed it was looking for it and got confused. Now I leave everything in, although I may change the restrictions so I can at least skip pasts these clips.
  4. @ DVantrease
    I remove the fbi warning in IfoEdit before I send it to IC7 and that works for me.
    Nov 2002
    London
    I too have had problems doing this. I suppose thats why the release doesnt allow this.
    Smurff
    To all those past and present. All those that have fought for our freedoms. God Bless. Those of you that are fighting now,
    keep your heads low. Those of you back home hold your heads high.
  6. How about do you have navigational issues if you only select menu (required) and main movie?
  7. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    Baker
    simple answer is not to use it to delete Titles, but it's fine to strip audio & subs, but it is not a Title stripping tool
    there are other methods you can use to give IC a valid DVD structure so that it can do the job it is best at
    and that's 1:1 backups of your video maintaining full DVD structure
    http://www.deano.dsl.pipex.com/GUIDE/home
