Hi, I'm after a little help please. What i'm trying to do here is to copy the basic menu structure from a DVD to add to a re-muxed film i have. The method i have used so far is to demux with smartripper to get rid of the extras etc and then re-muxed back into vob's using IFOEdit. Then for the menu's i have used InstantCopy to get the menu's from the original DVD, from what i can figure i have the correct menu's allready for me to somehow 'insert' the re-muxed film into.
Am i doing this the correct way, will this work ? The reason i'm trying to do it this way is so i can CCE the main movie (insted of letting Instant copy TRY to do it for me and fcuk up the size) and then use the menu's that IC creates. I'm assuming i'd need to use IFOUpdate somehow ? I've had a quick try and end up with a messIf anyone could point me in the right direction i'd be gratefull.
romprod
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 08:36 -
Perfect DVD copy with all the menu's but half the file size
By Kozanator in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2009, 09:44 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
Trying to copy a dvd made using convertxdvd no menu shows up
By brdhsby5 in forum DVD RippingReplies: 18Last Post: 17th Apr 2008, 09:33 -
DVD Lab "the subpicture of menu 1 is created from copy of external fil
By BeachNut in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 08:05
