Hey there. I've got this 766MB (~77min) mpeg-1 file that I'm trying to burn as a VCD. I wanted to add some chapters to it with VCDEasy and burn the resulting .bin file. Problem is, the final .bin file is 880MB (~88min) which is obviously too large. I'm not too experienced at this and I was wondering where the extra size/length is coming from. Thanks.
easy fix.
use TMPGEnc -- Mpeg Tools -- Simple Multiplex. Use your Mpeg as video and audio input. Choose a filepath for the remultiplexed file. Here's the important part -- choose type as MPEG1 VCD (Non-Standard).
This takes all of 2 minutes, doesn't change the quality, and will give you a file which won't require autopadding in VCDEasy.
[quote="uigrad"]I've been having the same problem. Re-multiplexing doesn't make much of a difference at
all. Is there anything else that I can try?[/quote
https://www.videohelp.com/forum/viewtopic.php?t=150087
i found useing simple-multiplex did not fit the bill and solve the problem but doing multiplex and de-multiplex like above shows to solve the autopadding issue
A bin file is always going to be larger than the sum of all the files it contains. I have seen 900MB bins which fit on a 74min cdr. Just load it into the disk imaging software and let it tell you whether it will fit or not. My guess is that your disk image will easily fit on an 80 min cdr. If VCDEasy's display in the lower part tells you it will fit, then it should fit regardless of how large the bin ends up being.
There are some other possibilities that might be inflating your filesize as well. As others have said, make sure your mpg is multiplexed correctly. In VCDEasy either turn off the update scan offsets option, you really don't need it, or take it into account when encoding. This option can increase filesize by as much as 80MBs. Other than that, just burn away. You should be fine.
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
MPEG Layer 2 video file, is it an editor friendly file type?
By ferran275 in forum Video ConversionReplies: 18Last Post: 17th Apr 2010, 00:41 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Converting audio from a mpeg file to a mp3 file?
By hrace in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 17:15 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 14:05
