Hey All,
Is it possible to add files to the CDDA folder so I can create an AVCD? I keep getting errors stating that the CDDA folder is forbidden "Special"...![]()
AnonymousGuest
VCD-Imager, which is the program VCD-Easy uses to create the VCD discs, automatically adds this folder but doesn't let you add the audio part, it was suppoused to be operational in future versions, but unfortunatly at this point I have no idea if it will be made...
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
Reading CDDA on my PC?
By DVDAl in forum Software PlayingReplies: 2Last Post: 9th May 2009, 12:44 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37
