Hi,
Ive got a movie in SVCD format .mpg - i want to open it up in premiere so that i can join/edit the files. It keeps giving me an error - i guess my version doesn't support it. (ver 6.0) is there a plug in or a patch for it?
John
not for version 6 ... but you can frame serve to it w/ dvd2avi and vfapi reader codec
Is it possible to edit MPEG2 in premiere 6.5 without converting to an AVI first?
I want to record TV and kill commercials later, but whats the point in capturing in anything less than RAW AVI if I have to convert to that before editing anyway?
thanks
PRO -
The following apps support MPEG-2 Editing:
Ulead Media Studio Pro 6.5 & 7.0
Ulead VideoStudio 6.0 & 7.0
SoFo Vegas 4.0
Adobe Premiere 6.5, although publishing to MPEG-2 cannot edit a compliant MPEG-2 stream. Hopefully 7 will catch up and offer this feature.
Regards,
Ivan
Premiere CS4 can't import AVCHD
By cheerful in forum EditingReplies: 24Last Post: 6th Mar 2012, 10:01 -
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
Adobe Premiere Pro CS4 Cannot Import .mp4 File
By spike32 in forum EditingReplies: 5Last Post: 19th Jan 2010, 08:15 -
Import JPEGS to Premiere
By videobread in forum EditingReplies: 1Last Post: 26th Aug 2007, 15:11 -
Premiere 6.5 won't import DV files
By Megahurts in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2007, 21:52
